Nieuwe Deutz?
Nieuwe Deutz?
Berichtdoor Niels » vr 30 jan, 2009 18:53
Dit vond ik op het internet.
En omdat er bij staat ''The new Agrotron L 720.''
is het denk ik een nieuwe. (of het is gewoon hele oude info maar kende hem nog niet)
Wel even in het Engels gelaten, want om alles over te gaan typen.... ... Heb ik niet zon zin in :D
A better way to farm. The new Agrotron L 720.
Tractors in the 200 HP class have to be robust, powerful, and above
all, economical. The new Agrotron L 720 features a state-of-the-art
7.2-liter common-rail diesel engine from DEUTZ (220 HP (162 kW))
mated to a new 18-speed power-shift transmission and a hydraulic
power shuttle. Another highlight is the electronic parking brake,
which makes operation much easier and is the first of its kind to be
installed in a tractor. also used in cars, the system is maintenanceand
wear-free and thus improves overall durability.
The cab was also redesigned to facilitate working in difficult
conditions. The lower portion of the windshield, for example, is
double glazed which, in conjunction with new insulating materials
in the floor, lowers noise levels in the cab by 3 db/A.
The 18-speed Power-shift transmission with two electrohydraulically-
operated gear ranges, makes it very easy to shift
gears. A total of 27 forward and reverse gears (including the
standard crawler gear group) ensure tight gearing for maximum
maneuverability. Power-shift stages are controlled automatically
(depending on the load) thanks to the new APS
system, which allows the driver to clutch or use the knob in
the gearshift lever. This makes it possible to conveniently shift
through 18 gears.
Productivity can only be achieved with large working widths.
Equipped with an oversized lifting cylinder, the Agrotron L 720
can lift extremely heavy loads (up to 10 tons). This allows even
the heaviest implements to be transported safely. Four additional
remote valves (one electric, three mechanical) are included
as standard.
(SDF)
Re: nieuwe deutz?
Berichtdoor Stigter » vr 30 jan, 2009 20:10
Zo alleen op het uiterlijk afgaand, is het echt een Deutz..
Re: Nieuwe Deutz?
Berichtdoor dwoertink » za 31 jan, 2009 11:06
Is al wel een aardig tijdje bekend.
Re: Nieuwe Deutz?
Berichtdoor Atte H » za 31 jan, 2009 23:02
Inderdaad, is al een aardig tijdje bekend als ik het me goed kan herinneren. ;)
Re: Nieuwe Deutz?
Berichtdoor René » zo 01 feb, 2009 15:14
Bah, zijn ze nou nog niet afgestapt van die vieze voorvelgen? :cry:
Terug naar “Deutz”
